disable policy
disable policy
Description
This command disables the ONEPolicy functionality.
Syntax Description
Default
None.
Usage Guidelines
None.
The following example shows how to disable ONEPolicy:
# disable policy
This command was first available in ExtremeXOS 16.1.
Platform Availability
